Catalin
Liquid Nepon
Sunday Morning    174
30 minutes ago, Catalin said:
thank you very much, this is the solution.
That's what I was talking about
Ur welcome . please issue ticket to customer service if you still facing same issue . :)
Liquid Cooling: Where do I connect the Fans and Pump? < try study this
How to determine if the pump is functioning on your liquid cooler < try study this
Catalin    0
Connect the pump and it works, I set in the topic you showed me somewhere above, once
The pump works, connected to sys fan speed, has about 6783-6818 rpm
The problem is that it does not go below 42 degrees
It is true that I use v3.efi, a modified bios a bit, to climb the processor to full turbo, as described by anandtech.
But that's not the boy, though
It's a super cooler, I think the best market to cure the beasts of i7 or xeon processors
I will see clearly after washing the radiator
By the way, is Nepton still made?
Catalin    0
From Romania!
On your link, There is no buy now button
Where can I buy a new Nepton 280l?
Here is no longer imported nepton 280 and I do not know why!
I do not buy new but second hand, it is not found for some good years!
Edited by Catalin
Sunday Morning    174
19 minutes ago, Catalin said:
From Romania!
Please submit an ticket at here : https://account.coolermaster.com/LogOn.aspx
Customer services will help you :)
And look this too : Nepton 280L
Oh ya you can try CM new products at here : COOLER MASTER MASTERLIQUID PRO 280
