Idea
Slim 360 Radiator WILL fit in the front.
Idea    0
So I recently did a full custom hardline loop, and I was trying to find out if a 360 radiator would fit in the front of the Mastercase Pro 5, but couldn't come across any sort of thread or answers... The only pictures I found were of that one guy that did the 24hr Le' Mans race car theme build. Although a REALLY dope build, I noticed he did some modifications to the case. So I just bit the bullet and ordered a EKWB Slim 360 radiator. It honestly fits PERFECTLY, and with plenty of room for fans as well. AND you can still use the hard drive cage in the power supply basement! However, y
ou wont be able to use the top two screws to mount the radiator, but that's honestly no biggie.
EKWB GPU/CPU Waterblocks
EKWB 140 Pump/Res combo
1x EKWB 240 slim radiator (top)
1x EKWB 360 slim radiator (front)
Corsair SP120 PWM Fans
Bitspower fittings
Bitspower 10mm ID/12mm OD Clear PETG Tubing
XSPC ECX Ultra Concentrate (white)
