Oak
Mastercase maker 5 Fan compatibility please
Oak    0
Just purchased the case and I'm planning on replacing the fans. I'm thinking more of 1500-2000rpm for better airflow. Does anyone know a good fans that compatible with this case ?
I'm eyeing at the notua 2000rpm but not sure if its compatible (and the steep price too)
THanks
Sunday Morning    177
Welcome to CM forum .
Hi Oak , May i know your temperature in your room and can share your specs detail ?
Im not expert on cooling system but the stock fans is pretty good to reduce our heat in system unless your parts are over heating its pointless or OC
Share some , i have pro 5 all is stock fans 140x3 + 240 radiator on the top ( overall temp ) is idle 30c and full load is 45-60c .
By the way if you want your case to look like a rave party then check out MasterFan Pro 120 Air Balance RGB .
Please contact Customer services , they will help you : https://account.coolermaster.com/LogOn.aspx
Create an account
Register a new account
Sign in
Sign In Now
