• Announcements
    • CM Nick
      AM4 Socket Support   04/24/2017
      Due to technical issues, the topic on "AM4 Socket Support" has disappeared. We apologize for any inconvenience this has caused and we are trying our best to have this topic back up as soon as possible.   As we read in the topic, there is a lot of discussion going on when the new brackets will be arriving. We can tell you now that the brackets will be ready for pre-order on our CM Store EU tomorrow and will be ready for shipment around the 16th of May.   You can continue the discussion in this newly created topic:
WSeong Lee
Masterwatt Lite 600W weak 12V output
3 posts in this topic
Just switch my old PSU to this new Masterwatt Lite 600W once everything setup done, I start up hwinfo64 and found that the 12V output on idle is 11.808?
That output is consider low as this is a brand new PSU!
Fire up a game and log the voltage, it is shown 11.808 max and min drop to 11.616 during heavy load.
How can this be? even my 10 year old PSU Acbel 450W perform better with max at 12.096 and min 11.712
my system is just a basic rig:-
i3-4160, 8GBX1 DDR3 RAM, GTX750Ti(no external source),Hyper 103 cooler
onboard speaker, gaming mouse and keyboard via USB, 2 512GB SATA Harddisk
0
Reading out PSU voltages from software is never 100% accurate.
If you have a voltmeter, you could use that to measure the 12v line.
11.6v is a bit low, it is well within the 5% margin that is allowed and the PSU will work as intended.
0
Posted (edited)
11.6 is more than a bit low, consider it is a new PSU, even my BIOS reading on start up confirm is 11.808, either the sensor is wrong or this is really a weak PSU.
I am more concern if the PSU can hold on for the 3 years warranty period, and if the PSU drop below 5% margin, will I able to claim a warranty.
Edited by WSeong Lee
0
Create an account
Register a new account
Sign in
Sign In Now
