• Announcements
    • CM Nick
      AM4 Socket Support   04/24/2017
      Due to technical issues, the topic on "AM4 Socket Support" has disappeared. We apologize for any inconvenience this has caused and we are trying our best to have this topic back up as soon as possible.   As we read in the topic, there is a lot of discussion going on when the new brackets will be arriving. We can tell you now that the brackets will be ready for pre-order on our CM Store EU tomorrow and will be ready for shipment around the 16th of May.   You can continue the discussion in this newly created topic:
Followers 0
Ayman Hadramot
AMD 8350 High Temperature with Cooler Master Seidon 120 v
3 posts in this topic
Hello everyone
I installed a Cooler Master Seidon 120v on my cpu AMD 8350 with Motherboard MSI 970A G43 and another cooler master fan 120 mm is installed in the PC Case
also I am using Cooler Master Paste the comes with Product
I live in Istanbul with 20c in day
the problem is :
IDLE Temperature is : 44 c with Cpu Fan 2000 rpm and PC Fan 1200
on Load Temperature is : 57 c with Cpu Fan 2000 rpm and Pc Fan 1200
so I am really not pleased with this results because I replaced my old Cooler system for this reason and I replaced it with liquid CM one because I heard alot about it but finally the performance is not like what Imagined
0
Welcome to CM forum .
Hi Ayman , Sorry late reply .
Suggest you contact customer services , they will help you and you check this link for your reference COOLER MASTER SEIDON 120V TEST AND REVIEW
0
Thank you for replaying
no it is not needed to contact with them
the problem was because of my Motherboard is not compatible with CPU after changing it the IDLE temperature has done from 44 to 15 c
thank you for your silent products really really I appriceit your products
0
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
