Carlos Santos
1st time Build - MasterCase Pro 6 liquid cooler question
Hi!
I'm building a PC for the 1st time and I have a question that I have been unable to find an answer for.
So, I bought the MasterCase Pro 6 and I've read on the specs about the radiator size limitation for the top, but there's no info other than the 280 support on the front.
Would a MasterLiquid Pro 280 fit in the front and would the tubing reach it with no problems?
I already removed the drive cages on the front and the design is going to be black with blue lighting (cage and if possible the CPU cooler itself) + the MOBA and RAM.
Thanks in advance.
If your curious about my build is my list of components for it:
- Cooler Master MasterCase Pro 6 (blue LED version) -> already bought
- Asus Crosshair VI Hero
- AMD Ryzen 1600X
- Thermal Paste ARCTIC MX-4 20G -> already bought
- Cooler Master MasterLiquid Pro 280 or Noctua NH-D15SE-AM4 (undecided for several reasons. 1 being the question above, the other main one being fear of water cooler leakage)
- G.SKILL TRIDENT Z RGB 16GB (2X8GB) DDR4-3200MHZ CL14
- Cooler Master V750
- SSD M.2 2280 SAMSUNG 960 EVO 500GB TLC NVME -> already bought
- GPU (UNDECIDED - waiting for AMD Vega information/release for comparison with Nvidia cards. Last component to get)
- 2x Noctua NF-A14 industrialPPC-3000PWM -> already bought (might buy an extra one for the front should the liquid cooler not fit)
Sunday Morning    178
Welcome to CM forum .
Hi Carlos . Base what we know , Master Case Pro 6 able handle 280 radiator at the front , you can refer this link : MASTERCASE PRO 6
and below is picture ( Real picture pro 6 with master liquid pro 280 ) for your reference .
i would like to say thanks to GCC team APAC ( Bro Tom and Jerry ) help me provide this picture . Ur the best man .
Hope this can help .
  • Upvote 1
Yes, that is exactly what I wanted to see! Thank you! :D
  • Upvote 1
Create an account
Register a new account
Sign in
Sign In Now
