Dima
Nepton 280L PWM problem
Dima    0
Hi all,
was wondering if the pupm supports PWM function.
My pump got a 4 pin connection, and i've connected it to the CPU_FAN.
But for some reason when I change in bios from DC to PWM the pump just goes to 100%, even though the cpu is only 26 degrees hot.
Ive got ASUS Z170M-PLUS motherboard.
Any ideas ?
Edited by Dima
Mohd Noh    179
16 hours ago, Dima said:
Hi all,
Any ideas ?
Hi you can check this thread :
Dima    0
Thanks, problem solved.
I didnt notice that the pump is a 4 pin connector with only 3 wires.
So I just changed CPU_FAN From PWM to DC.
Create an account
Register a new account
Sign in
Sign In Now
