jeremy
MasterCase Maker 7 Ideas
jeremy    3
First, where is the MasterCase Maker 7? We have been waiting for this case for over a year due to the fact it is an XL-ATX case.
Case Idea
• 2 versions to be available 1) Metal parts and upgrades 2) Plastic parts and upgrade (current).
• Front IO to be a non-gloss finish
• Have available different colored interior versions available, much like the 5T (black, Red, Green, Blue, White etc)
• RBG lit fans to be standard with all builds with an RGB controller on the front IO (RGB fans can also be integrated into supporting Motherboards for customization)
• Top cooler rack to fit up to a 3x120 or 3x140 radiator.
• More rear SSD hold racks
• PSU lower shelf cover to be standard (no one wants to see messy cables)
• Motherboard bay side to have the tinted tempered glass side panel
• Cable management side to have a metal side panel (can order another glass panel if you want this option)
• New upgrade mod front fan cover to be flush with the IO (opening for airflow at the bottom of the cover instead of the top) Reason: the open hole looks like an opening to a garbage basket.
• Disc drive shelf to be customizable to face forward, or sideways (looks amazing to have a fan controller or LED screen on the inside faced towards the tempered glass)
Edited by jeremy
  • Like 1
