• Announcements
    • CM Nick
      AM4 Socket Support   04/24/2017
      Due to technical issues, the topic on "AM4 Socket Support" has disappeared. We apologize for any inconvenience this has caused and we are trying our best to have this topic back up as soon as possible.   As we read in the topic, there is a lot of discussion going on when the new brackets will be arriving. We can tell you now that the brackets will be ready for pre-order on our CM Store EU tomorrow and will be ready for shipment around the 16th of May.   You can continue the discussion in this newly created topic:
Followers 0
Dorjan
CM B500 v2 strange smell under load
2 posts in this topic
Hello im having a problem when underload my psu start to smell when i get close to it.Its noticeable when gaming but if i increase cpu fan speed max ,cause psu it on top of case it goes away or if i remove the side panel it goes away also if example i play heavy game then turn off pc right after i finish the smell is more noticeable.Only way to remove smell is to put cpu fan at turbo speed which is very noisy is smth overheating or smth about to die?.Also at first i thought it was my gpu cause switched from gigabyte xtreme software to msi afterburner it bugged gpu fans at 0% underload while playing demanding game gpu reach 99C but for like 10-30second before i manually turned gpu fan to max then a  smell started then removed gpu to check for smell and inspect it it didnt had nothing wrong,it was near psu there where it was im sure now its psu idk how that can affected psu.My question is should i use this psu its been a week since it happend my psu is 4 month old also hole pc is 4 month old same day bought all parts if that helps.Am i  in danger of causing dmg to other parts or its fine ?
My Pc  is very low power usage  i have a i5 6400,8gb ram,gigabyte gtx 1060 windforce oc 6gb,1tr hdd and a 500gb hdd windows 10.
0
Create an account
Register a new account
Sign in
Sign In Now
Followers 0
