Daniel Adams
Hyper 212 LED Turbo not fitting correctly on AM4 board
Hi all,
Recently I received all the components for my Ryzen 7 upgrade. One of the items is a Cooler Master Hyper 212 LED Turbo which according to the website, packaging and instructions is fully compatible with AM4. Well, I'm afraid to say that is just not the case. I've been spending hours today trying to make this cooler fit on my ASUS board to no avail. It seems the retention clip provided with the kit will in absolutely no way clip close on the motherboard's bracket unless I bend it in such way that it defeats the purpose or worse still, damage the CPU or motherboard.
I've also Google'd like crazy with no results. Unfortunately the platform and cooler's too new for there be any helpful tips out on the web.
If anyone can help it would be greatly appreciated.
The motherboard in question:  ASUS Prime X370-Pro
Edited by Daniel Adams
  • Upvote 2
xtian1    13
Hi Daniel,
We are sad to hear you are having difficulties with your installation. Could you provide us with clear and detailed pictures to get a better understanding of the problem itself and that way involve the business unit for assistance on these new models.
Regards,
Xtian1
RP    0
I also bought this cooler for a black and red AM3+ build i'm doing and was hoping to use this cooler along with the case and PSU for a Ryzen 5 build later on this year.  However upon receiving the cooler i noticed it only comes with bracket for the plastic AMD attachments on the motherboard this puts the cooler with the fans pointing up and has no option to rotate the cooler 90 degrees for sideways mounting.  I did a quick internet search and noticed Noctua do a really extensive kit for the AM4 socket that allows their coolers to be rotated 90 degrees. Are their any plans for cooler Master to provide the same for their customers especially since the Hyper 212 LED Turbo has the logo written on the heat sink for a east-west rotation????  Also will future coolers come with a back Plate style attachment for AM4 like the AM3+ and Intel socket does at the moment or will future coolers rely on the plastic tabs on the motherboard???
drgoku    1
Me and my friend faced the same issue when building on the am4 asus b350 prime board with the cooler master hyper 212 led turbo. The bracket is too tight and it doesn't fit. We were scared we might have damaged the cpu when trying to lock the cooler in place. We loosened the plastic brackets on the motherboard and clipped the retention clip. Then screwed the plastic bracket in tight to a  level we were comfortable with. This was ofcourse not the default height the plastic brackets on the motherboard were at. Scary stuff. Luckily no damage was done with our earlier shenanigans and the board posted.
This shouldn't be happening to us especially with a reliable brand like cooler master. The retention clip was obviously a few mm shorter. Luckily we opted out of using brute force midway after we found this thread and learnt we weren't the only ones facing the issue.
Edited by drgoku
drgoku    1
On 4/25/2017 at 2:11 PM, Mohd Noh said:
Yes! Ofcourse the  cooler we bought had am4 compatibility written on the box and had the two slits on the base to slide the clip through!! It also had the manual mentioning how to install the cooler for  am4 motherboard. Why would I be raising an issue about am4 compatibility if the item and the manual didn't state am4 compatible? Please do not insult our intelligence.
I have also said in my post that we managed to mount the cooler by loosening the plastic brackets on the motherboard. Do you also think that I have magically mounted a non am4 cooler on my am4 motherboard?
Shane    0
Same problem here i ended up forcing it on. Ive ordered a new cooler and its not cooler master. Very disappointed
Mohd Noh    179
Hi Shane , please issue ticket , customer services will help to solve this issue .
Ankit Raj    2
Hello, I am having same issue here.
Hyper 212 LED Turbo cannot be rotated and mounted such that the cooler fins align parallel to the DIMM slot on the motherboard.
(See image attached)
In the image, the blue shaded region is the cooler fins (or heat sink fin). The blue arrow is the air flow direction. The blue orientation is the only way how  the cooler can be attached. This is very restrictive for small cases which do not have exit port on right (of this image)
I am looking for mounting the cooler, as shown as red shaded orientation, where the direction  of air flow is in red colored arrows. ( in this orientation the fins are parallel to the RAM or DIMM slots).
Can CoolerMaster help with this. ( I own a Hyper 212 LED Turbo presently and all hardware is just sitting there to be used !)
Edited by Ankit Raj
Added more information
  • Upvote 2
Mohd Noh    179
Welcome to CM forum
Bhai , please contact customer services and tell them regarding this issue .
Issue ticket at here : https://account.coolermaster.com/LogOn.aspx
Create an account
Register a new account
Sign in
Sign In Now
