Daniel Adams
Hyper 212 LED Turbo not fitting correctly on AM4 board ( Solved )
ddv88    0
On 26.01.2018 at 8:52 PM, Jayson Teng said:
Hi Guys! I would like to thank CoolerMaster for promptly resolving my issue! I received a reply from them last Jan 9 and the bracket was shipped out last Jan 13. I already received the mounting bracket and already installed it! Thanks CM!
How did you do that? I have same brackets, but can't install it. I tried all of the mounting screws from the package. (Asus ROG Strix B350.)
Did you remove a backplate from the motherboard?
fff3cf59012bcb3eaa889577c2acb24379b6bfa9aafad09591dd5019de9d5607.jpg.d805e04a9131b3414c7d64ccba103c44.jpg
Edited by ddv88
Mohd Noh    29
On 2/6/2018 at 7:29 AM, Papa Alpha Oscar said:
I just started my own support ticket and included the posted pic for the bracket. I wonder if I'll get the same response.
Hello
Please patient our customer services will reply your ticket as soon as possible .
9 hours ago, Mohd Noh said:
Hello
I don't think getting a response is the issue, its the problem that some are being allowed to get the bracket, and others like myself are being flat out told that there is no bracket.
  • Upvote 2
John    1
Same thing for me but more - I bought an Asrock B350 Fatality mobo to go with my Ryzen 5 1600x CPU. As the 'x' series don't come with coolers, decided to buy a CoolerMaster Evo 212x
Firstly, the screws that came with it did not fit in the stock backplate that came with my mobo, and the backplate I was provided with (from CM) did not align with any of the holes around my CPU in the motherboard. Even if the backplate aligned or the screws fit, the "AM4" bracket doesn't even fit. It's too short and the only way to get it to fit would be to just shove it in and (when tightened) damage the mobo.
Not happy at all with this false advertisement, last time I buy a thing from Coolermaster.
(Below I have shown the incompatibilities. On the image with the arrows I am showing where the screws are supposed to fit but do not. In that image is the stock backplate that came with the motherboard.)
  • Upvote 1
Jayson Teng    1
 No, i did not remove the stock backplate of my tomahawk b350 mobo. i only used the screws and the bracket that they shipped to me and was able to attach the heatsink vertically.
Edited by Jayson Teng
  • Like 1
Mohd Noh    29
2 hours ago, ddv88 said:
Ok. Waiting for support answer..
Please patient , they will answer your ticket
ddv88    0
I got default answer. Bla bla ... you can install it with plastic bracket ... bla bla ... here the link to manual ...
But this plastic backplate is not fit to mounting holes.
Edited by ddv88
Their support is pretty disappointing. Between their crappy claim of AM4 "compatibility", and their support randomly picking who they help and who they tell to shove off, I am done with CoolerMaster.
This topic is now closed to further replies.
