William Jackson
HAF X max radiator size
CM Michiel    13
Hi William,
The maximum radiator size supported by the HAF X = 360mm ;)
Be aware that the two 5,25 drive bays at the top can't be used when installing a 360mm radiator.
CM Michiel    13
Hi William,
Unfortunately a 280mm radiator (MasterLiquid Pro 280) will not fit in the HAF X.
The screwholes at the top will not line up with the screwholes from the radiator.
Let me know when you have any other question.
CM Michiel    13
Hi William,
You can install the MasterLiquid Pro 240 in the top of the HAF X.
