Rohit    0
HELP!
I order a Coolermaster Quickfire TK Keyboard almost a year ago through Amazon - it has media controls when the fn key is pressed (so the orignial fn keys are off for that time).
Because I'm silly, somehow I broke the FN key so the stem was snapped in the keycap. I tried fixing it, and somehow the FN key is jammed down and the stem is stuck in the pressed mode. Because of this, the FN key is on constantly, which means the media keys are enabled permanently and the F1-12 keys are unusable.
I doubt this is under warranty, but is it worth contacting support? Are there any fixes I can make to disable the key (obviously media controls are not as important).
Please help me, if you can.
P.S. The way the key is meant to work is - The default state is F1-12. If you hold the FN key while pressing one of these, it will activate the media controls instead. Holding it for 3 seconds puts it in this mode permanently. THIS IS WHAT STATE I THINK IT IS IN, I CANNOT CHANGE IT.
PPS. My S key LED is often dim/gone randomly, another issue but I'm not bothered about this. Maybe it will help me be more eligible for warranty?
Edited by Rohit
