mohammed
an issue with GTS V8 Air Cooler
mohammed    0
Hi ,
find solution to my issue for cooler master cpu cooler maker GTS V8 With the Cooler master master case 5 the cooler now is tite with the case panel so some times when we try to run the pc it crash and couldn’t start and after we open the side panel for the case it runs perfect.
Over all im happy with cooler master products and I have a lot of your product in my last 2 buld the v850 psu, cooler master master case 5 Nvidia ,GTS V8 Cpu cooler ,Cooler master master Case 5 and geminii S524-v2 cpu cooler.
And my issue is on
build
CPU                       Intel Core i7-7700K 4.2GHz Quad-Core Processor
CPU Cooler         Cooler Master V8 69.7 CFM Rifle Bearing CPU Cooler
Motherboard        ASRock Z170 Pro4S ATX LGA1151 Motherboard
Memory                Corsair Vengeance LPX 16GB (2 x 8GB) DDR4-3000 Memory
Storage                 Silicon Power Slim S55 240GB 2.5" Solid State Drive
Video Card           MSI GeForce GTX 960 4GB Video Card
Case                     Cooler Master MasterCase 5 ATX Mid Tower Case (Whithe)
Power Supply      EVGA SuperNOVA NEX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply
OS                         Microsoft Windows 10 Pro OEM 64-bit
And im looking ahead to make an solution for that without change my
build
I see some suggestions :-
1.make an custom window pups out an few mm.
2.change the motherboard stud's.
Thank you
Mohammed Almawlani
