xperia
a fancontroller for nepton 280l
xperia    0
Hi,
I'm using it for two years and yesterday he made his third victim, Fan Pin nr. 4. (before Cpu Opt and Fan Pin nr.1).
 I have 2 fans 140mm 4 pin + 1 pump 4 pin + 3 generic fans 3 pin... but only four pin  still alive on motherboard.
so now i'm looking for a fancontroller,  i need at least something with 4 channels  with 4 pins per channel (i can connect/handle the fans whith 3 pins on my motherboard ).
Which one is the most effective and efficient for my nepton 280l?
thanks
Sunday Morning    178
Hi today alot of out there have wire like pwm fans splitters y cable 4 way can connect from motherboard. Maybe this useful and save your $$$
xperia    0
yes, but  my fan pins are dying one by one, i need a permanent solution, a fancontroller fully compatible with nepton 280l is the ideal i think, and the fans make too much noise i would like to control them
Edited by xperia
Create an account
Register a new account
Sign in
Sign In Now
