xtian1
Cooler Master’s CPU Cooling, Power Supplies Synced with Kaby Lake and Ryzen
xtian1    10
Intel and AMD’s announcements of their next-gen Kaby Lake and Ryzen processors might have some of you wondering whether you’ll be looking at a total overhaul of your cooling and power supplies to accommodate the new chipsets and motherboards. Cooler Master, a leader in design and manufacturing computer components and peripherals, has already prepared for the launch of these CPUs so you can apply your existing CPU coolers and power supplies to the upgraded chips.
Power Supply Compatibility
Here is a list of Cooler Master’s power supplies currently compatible with next generation processors:
MasterWatt Maker Series
V Series
GM Series
New GX Series
Air and Liquid Cooling Compatibility
Virtually all of Cooler Master’s liquid and air coolers are compatible with Intel Kaby Lake’s LGA 1151 socket. For AMD Ryzen’s AM4 socket, any models lacking native compatibility can be adapted using an upgrade kit. Check the LINK for compatible models, and contact your local retailer or tech support to check for the availability of upgrade kits.
  • Downvote 1
Streamer    0
So, no plans for V8 Ver.2 cooler (http://www.cmstore.eu/cooling/v8-ver-2/
http://eu.coolermaster.com/en/cooling/cpu-air-cooler/v8-ver2/?lv01_type=cooling&lv02_type=cpu-air-cooler&prd_path=v8-ver2) ???
I'm a bit concerned since this is an expensive and great cooler for not receiving an upgrade.
Edited by Streamer
knud    129
You would need an upgrade kit for the MLP 280 as well. This will be ready at the end of Q1.
Bdiddy    0
I have a question about the MasterLiquid120. It states its AM4 compatible on the list above and on the advertisement on CM page. The model is MLW-D12M-A20PW-R1. On newegg i only see model MLY-D12X-A20MB-R1. Is that compatible model with AM4 without upgrade kit ? I dont see model MLW-D12M-A20PW-R1 for sale in the US.
Brutos    0
So how will I go about getting one once its released ?
