Steel
Compatibility with upcoming am4 motherboard? (Hyper EVO 212)
Steel    0
Hi!
I am new to this forum and have been searching on the web if coolermaster was planning on releasing something to make the Hyper EVO 212 compatible with the upcoming am4 board. Since i have not found anything solid, i thought to ask here first.
Inimbrium    0
So here's the latest info I've found. The mounting hole distances are definitely not compatible with the backplate as shown in the diagram drawn by me (Paint FTW), however the scissor mount should still fit as AM4 hole diagonal distance seems to be within the tolerance of the adjustable linear holes as their range are between 100mm and 117mm and thus 104mm fits well within that.
Ignore this second picture. I just don't know how to remove it from the post!
Edited by Inimbrium
edited some numbers
CM Michiel    15
Hi all,
The Hyper 212 EVO will support socket AM4  :)
There will be an upgrade kit for the Hyper 212 EVO in the near future.
We unfortunately do not have an exact date yet when these kits will be available.
Info will come a.s.a.p.
Let me know when you have any other question.
  • Upvote 2
Hello,
Just came across this information:
http://www.eteknix.com/cooler-master-announces-amd-ryzen-am4-compatibility-list/
2 Questions:
1. Is this taken from any oficial Cooler Master source? I cannot find it in the Cooler Master news section.
2. If is official how do we know if our version of the 212 EVO will be compatible or not?
Update, Just found the official press release:
http://www.coolermaster.com/company/press-release-M1701190001f278-20170119.html?page=1
Edited by SDato
  • Upvote 1
CM Michiel    15
Hi Andrey,
It's indeed not in the official press release, we will update it a.s.a.p.
The Hyper 212 PLUS is compatible with socket AM4 :)
You can pre-order the AM4 upgrade kit on our CM store:
EU: http://www.cmstore.eu/cooling/amd-am4-upgrade-kit-rr-accy-am4b-r1/
US: http://www.cmstore-usa.com/amd-am4-upgrade-kit-rr-accy-am4b-r1/
It is available free of charge, simply pay the shipping fees to receive it ;)
Let me know if you have any other question.
  • Upvote 1
