Apeiron
Haf 922 max radiator size
Apeiron    0
Nice!  thanks for your post, they are very helpful
Maybe for me, the better option is go for 240mm radiator water cooling.
I've been using a V8 air cooler but was thinking of liquid cooled for the 8700k I am upgrading to.  The V8 still works but its 5 years old and don't want fans to die anytime soon.  So with the masterliquied pro 240 are there screw holes that just line up with the case or did you have to drill the case?
Create an account
Register a new account
Sign in
Sign In Now
