Apeiron
Water cooling for Haf922
Apeiron    0
Hi all.
I need recomendation for water cooling for me Haf922, I have a fx8350 oc 4.5ghz and it is very hot. Now Im using a H80i of Corsair but it is failing (clicking noise and low performance) so, Im thinking in a more bigger radiator like a 280mm but not secure if it fit in the case (haf922)
Can some helpme?
Best regards.
Sunday Morning    177
Hi Apeiron
Sorry overlook your post , By the way im not pretty sure if HAF 922 can support up to 280m but you can check this link : HAF 922. H100 fits perfectly
Hope this can help , others solution please submit a ticket to CM customer service at here : https://account.coolermaster.com/LogOn.aspx
