Cata
Vents problems
Cata    1
Hy, i have the same problem, with vent.
i have conected pomp and i think work good
But my fans, fans do not start with the system, and load temp of 70 degrees receive.
reboot and go into the BIOS, do not change anything, but give save & exit and work for now
after one ore , i see in HW monitor, they dont work again
why do it?
pleese answer to me, i have big trouble
Cata    1
i have an i7 5930k, asrock x99 oc formula, msi gaming z gtx 1080, coler master 1200w and coler master nepton 280l
I have the pump conected wit cpu fan
Fans at cpu opt
How to reinstall cooler?
its very good how it is installed
you dont tell, why do this?
you say to put the pump on a system fan?
and the 2 fans of radiator, goes to cpu 1 and cpu opt?
i set the fans at minimum 20%, when is idle and they have 0 rot /min
its custom fan set, from 20% to 100%
i ask, if this can be a problem
Edited by Cata
please read here
Sunday Morning    177
may I know how you connect your nepton??
what I know the nepton can handle your system
my suggestion try reinstall your nepton and see the result
  • Downvote 1
Sunday Morning    177
Try follow step as below :
1, How to determine if the pump is functioning on your liquid cooler
2, Liquid Cooling: Where do I connect the Fans and Pump?
So my suggestion try remove and install back your nepton . if you still facing same problem , i would like you to contact customer services
Here the link : https://account.coolermaster.com/LogOn.aspx
Cata    1
yes, i see the link
the pump work well, after 8.5k
only change can i make its to move pump to connect to sys fan 1 and the fans to cpu 1 and cpu opt.
my work for daily use, at 4.5ghz with 1.258v, i have an golden processor i7 5930k
i convert every day, videos an i need my liquid cooler to work well
i have an thermaltake v71 case and i have system some like pull and push.
radiator fans push and thermaltake fans pull
maybe i have this problem, because i use formula drive for fans, i dont know
Cata    1
Yes. Frome bios? Or what?
i told you, i see your links
the pump works very well
i wanna try, to put the pump on sys fan1 ,
and the radiator fans to put at cpu fan and cpu fan opt
i hope you se what i write
Edited by Cata
Sunday Morning    177
i wanna try, to put the pump on sys fan1 , <<<<<<<<< YES
and the radiator fans to put at cpu fan and cpu fan opt <<<<<<<<< YES
i hope you se what i write ( try run full speed )
Cata    1
just now i finished the change of pump and radiator fans
now work fantastic
in idle, only 1 radiator fan work, but in a task, works both at best speed
pump in atache to my power speed fan and work great, you will see in picture
thanks very much bro, many thanks
how to calibrate and work egualy speed, both radiators fan? (last question)
Edited by Cata
