xtian1
MasterCase Maker 5t - Modders Inc Review
xtian1    13
" With a design that marries the original full-tower CM Storm Trooper/Stryker with the MasterCase 5, the new MasterCase Maker 5t is equipped with a top handle and is compatible with Cooler Master’s FreeForm modular system. This means that like other cases in the MasterCase series lineup, the MasterCase Maker 5t can upgrade parts incrementally, swap components with other cases from the same family and can easily replace some features it necessary, making it a perfect case modding platform to personalize. "
- Modders Inc
You can find the review here
markenpuff    0
The front case cover is nice, but they should have put screened openings on each side for better airflow. This can easily be updated with a new front cover design.
I may design it myself.
Create an account
Register a new account
Sign in
Sign In Now
