Chylvain    0
Hi all,
Happy new year,
Got a problem with my Masterkey pro S i bought 3 weeks ago.
When I choose a program with a lot of colors at the same time, I hear a sort of whistling in my ears (I am using CM Storm Resonar).
Exemple : if there is a wave from no color to full white color (like a heartbeat), when all the keyboard is white I can ear a whistle in my ears, then it stops when the color is OFF, and start again when the keyboard is full colors).
It's almost impossible to take a program with full colors...
Thank you for your help...
Leebyn    4
I think you might be hearing the PWM sounds. Someone else made a similar thread as you here:
so it might be the design of the RGB LED colors being altered through PWM.
kartana    5
I also have the high pitched noise, mostly with solid colors. Some do make more noise than others though.
Try a solid color like 220/220/220. That makes the most noise on my keyboard. I can hear it from 2 feet away :?
It seem like since they switched the forums here, support doesn't reply anymore....
It must be possible that some technician from CM can take the Masterkeys Pro Series keyboard, go into a quiet room, set the color to 220/220/220 and take is ear next to the F12 to see if there is a loud buzzing sound. If you set it to 220/220/220 you wouldn't even need to go that near since the buzzing is so loud that you hear it from a few feet away.
You basically can not use any colors above 120 unless it is 255 since there will always be a buzzing sound. Only full colors like 0/255/255 are quiet.
Please CM, we deserve and answer!
Edited by kartana
