KostonDemon
USB Led doesn't light on
KostonDemon    0
Hello :)
This is my problem with the case Cooler Master Maker 5 :
USB Led does not work... no light on
PS : sorry for my bad english (i'm french)
Solved by the Cooler Master Support  :
Do you have connect also the Molex cable from the fan/LED control PCB?
The Molex provides power to the fan controller and the LEDs on the top IO panel.
Check also this link for a short explanation and check if everything is connected properly:
http://coolermaster.force.com/pkb/articles/en_US/FAQ/Install-MasterCase-Maker-5-LED-Fan-Controller-PCB/?q=mastercase+maker&l=en_US&fs=Search&pn=1
>>>> Thanks a lot to the Cooler Master Support : it works !
I forgot to tonnect the Peripherial Cable connection to a 4pin Molex Connection from my power supply.
I would like to wish you and your family a very happy new year.
Best regards,
Eric E.
Edited by KostonDemon
Solved
