Andrea
Masterkeys Lite L ctrl+shift+[key] problem
Andrea    0
Hello.
I hope this is the right place.
I've recently received the MasterKeys Lite L bundle (keyboard + mouse), italian layout: it seems a nice product, nice feeling and design.
But it had a problem: it doesn't trigger the keys when pressing in combination "left ctrl" + "left shift" + "P" (also other keys, but not all of them; like "left ctrl" + "left shift" + "F" and "left ctrl" + "left shift" + "I" works).
I thought it was a faulty one and asked for a substitution; the new one arrived today and it has the same exact problem.
I already opened an issue through CM support, but in the meantime I was curious to know if this happened to others as well.
Regards and sorry for my bad english.
Andrea    0
Just wanted to update the status of this issue: CM replied to my ticket saying that it's "normal" that some key-combinations won't work in the MasterKeys Lite L as it doesn't have NKRO; I replied that on their website they do not say NKRO but they do say it has anti-ghosting up to 26 keys; their reply was that it apply to only a subset of keys (which is not mentioned anywhere).
Also, CTRL and SHIFT are modifier keys, so it's kind of their job to work while other keys are pressed.
As I would have liked to know it beforehand, it seemed right to update this thread; the problem is in the MasterKeys Lite L with italian layout: I have no idea if this is also a problem in other layouts.
Regards.
Bump.
I just bought one with portuguese layout. It looks amazing and feels pretty good. But I've found a couple problems so far.
leftCtrl+leftShift+P does not work
It seems to work when using the right hand Ctrl and Shift though.
The NKRO argument sounds absolutely bogus to me. Ctrl+Shift combos should work even on the most basic of keyboards.
Andre    0
Funny... left CTRL+SHIFT+P doesn't work but right CTRL+SHIFT+P work...
I have cooler master ms120 and this wasn't cheap.
@Cooler Master any assistance on this?
Malin Strid    0
I seem to have a similar problem. For me it is the ALT GR-combos that don't seem to work. Since I primarily work with a Swedish keyboard layout, this means I can't write for instance "@" without workarounds like copy-paste or changing keyboard language. It is, well, inconvenient to say the least.
(Interestingly enough it doesn't seem to be possible to write these characters with a virtual keyboard either? Perhaps it is not the physical keyboard but some software or system problem? When using a Swedish layout I can't write @, with UK English I can't write á, not even on a virtual keyboard)
