Sheri
CM Storm Enforcer Front fan.
Sheri    0
I've had the CM Storm Enforcer case for a few years now and have already had to remove the screen for the horrible noise it makes when it gets stuck on that big front fan.  Well, just a few minutes ago my who PC shut down, from what I assume is heat, because when I restarted, my front case fan was not on, but the rear fan was working as usual.
Is there any way I can take the front fan out and replace it or am I just going to have to put another fan on the top set up to make up for the fan not working in front?
Sunday Morning    177
Hey Sheri
Welcome to CM forum
You can check as below
http://www.cmstore.eu/enforcer/
http://www.cmstore-usa.com/fans-1/
if not in the listed ... i would like to suggest you to contact Cooler Master customer service.
Since the front cover is removal i think you can change or take out the fan and replace it with new one.
Hope this can help .
