krotos1970
the new master fans need led
krotos1970    1
these new fans need to have led's plus if they are not static pressure fans then why make them run so fast?
especially the 140mm, you only need 1200 or 1300 max rpm's for air flow, PWM from 500 or 600 to 1200 or 1300 and for the 120mm probably 800 to 1600 rpm's at the most, we don't need jet engines inside our PC cases.
