RoyK
Masterkeys Pro S (FN function key and several other keys stopped working)
RoyK    1
Hello.
3 days ago I bought a Masterkeys Pro S.
Very happy with the keyboard it functioned normally.
But since yesterday suddenly some keys stopped working, also the FN key doesn't work anymore.
FYI nothing happend with the keyboard.
(Lighting still works, and only via the software i can change profiles)
So i cannot reset the keyboard, i tried to reinstall the firmware but still no luck.
Does anybody knows about this problem, or can suggest help?
Can I send it back too CM?
Greetz
  • Upvote 1
knud    129
Have you tried the following?
  • Reset:
    • unlug the keyboard
    • press FN+Right Alt
    • replug the keyboard back in (while keeping FN+Right Alt pressed)
  • Clear onboard memory:
    • keep the keyboard plugged in to the PC
    • Press FN+E for about 3 to 5 seconds
Does the same happen when connected to another PC/Laptop? And are you using USB 2.0 or USB 3.0 ports?
  • Upvote 2
RoyK    1
I tried the steps you explained.
Used the keyboard with USB 2.0, the weird thing is that everything worked properly the first 3 days, and then suddenly the issue with the not functioning keys appeared.
The steps dont work, the FN key doesnt work at all so im guessing thats why the steps dont work.
I dont know if there is someway to downgrade the firmware of the keyboard, and ofcourse if that would help anyway.
I also tried trough USB 3.0 still the same keys are not functioning, laptop the same.
Greetz
knud    129
That is too bad to hear :(
I suggest you apply for RMA at the store where you purchased it.
Rix    0
Hi, I have a quite similar issue, only worse. The backlight is not working at all, let alone the Fn key.
I have followed your instruction above, and I have reinstalled the software, but there is nothing work. I cannot change the mode at all, the backlight is not working at all as well.
I just bought it a few days ago, and just started using it for a shortwhile.
Please let me know.
My Ctrl key stopped working after 10 minutes. No backlight when I press it either... Funny how my old PS2 keyboard lasted for years and this that cost 10x more lasted 10,000x shorter.
Edited by Kristoffer Carlsson
fanzouze    0
  • Reset:
Thanks Mr Knud, helped me to solve my problem in 2019
Nikhil    0
  • Reset:
This works. Although, somehow the Num and Caps lock stopped lighting up, but this was solved by unplugging and replugging the keyboard. Thanks!
