Sirirach
Masterkeys Pro L have a problem....
knud    129
Does this happen when the PC is on or off?
Does it happen in other light modes as well? The leds that stay this way --> can the color still be changed?
Sirirach    0
When the PC is on only.
Does it happen in closed light and other modes at button light off.
msZero    0
wow I have this exact issue. I've commented on another post about always on light but your sequence of light is almost as mine except for > I have Nupad 1
Update:
I've also went into the software and manually adjusted the colors to a static dim yellow. As you can see from the image attached the keys in question are always on as dim red as the color around them gets distorted.
Do I need to RMA the keyboard?
Edited by msZero
msZero    0
Have you updated to the latest firmware 1.2.1? I think that might be the reason. Now that its daytime outside I can't recall the leds being on when I first plugged in the keyboard on Monday. That or because I was so busy I did not notice.
If so can we rollback to a later FW version?
Edited by msZero
Sirirach    0
I rollback FW to 1.1.5 it also the same. You have to wait new version.
knud    129
Hi All,
Can you also try these 2 things, just to rule some stuff out.
  • Reset:
    • unlug the keyboard
    • press FN+Right Alt
    • replug the keyboard back in (while keeping FN+Right Alt pressed)
  • Clear onboard memory:
    • keep the keyboard plugged in to the PC
    • Press FN+E for about 3 to 5 seconds
