Johannes
How to use first the Cooler Master Nepton 240m?
Johannes    0
Hey everyone,
I just bought a Nepton 240m. It is my first AIO cooler and I got some Qestion.
Can i put it direct on full rpm or do i need to build up the rpms?
And how long will it take that?
knud    129
Hi there,
The pump should be set to full speed (if you have the cable, you can connect it to molex/sata directly)
The fans you can connect to a PWM header and set the fan profile you prefer. Or set to 100%. That is up to you.
Normal fan speed up is a few seconds.
Johannes    0
Hey Knud,
I have done what you said, i put the pomp on the molex and the fans on the PWM header.
But now after 2 days my pump is making a little more noise. What should i do? Just run it and hoping that it will go away or do i need to RMA (where im not really fan of)?
knud    129
Hi Johan,
There are 2 things you could try:
  1. Power off the PC first. Gently wiggle the case --> this will allow the water in the loop to distribute more evenly.
  2. If you have a free 4pin header on your motherboard: Connect the pump cable to that header and set the speed to ~90-95%.
Sunday Morning    174
Hey Knud,
I have tryed all what you had said before but even on 90% is the noise there.
What should i do?
could be that is air bubbles ...
knud    129
I hear 2 sounds - but not sure if they are both from the pump?
  1. rattling sound
  2. High electronic pitch
Which ones comes from the pump? (Can you pin point it?)
