darude_boy
Centurion 5 Front USB problem
lianfu    0
Thanks for the tip. I finally got my centurion 5 usb front working. But there is one slight problem, could you tell me where to put the ring from the firewire connector? (I think it's supposed to be ground - don't know anything about electronics :P) Is the ring supposed to be on top of the front panel pcb or the bottom? I kind of forgot where it was before I took it out.
detritus    0
I'm not so hot on electr(on)ics either, but I would guess that anywhere where it is in contact with the bare metal of the case would be fine, because the entire case should be grounded through your PSU.
