Lov2Drift
Need a little help
Lov2Drift    0
I bought the Real Power 450W PSU and it came with that wattmeter to mount in the 3.5 bay. I've got a centurion 5 case and for the life of me I couldn't get the silly thing to mount correctly. is there any way to do it so i dont have to drill holes into the case for some screws?
Cobra19    0
i'm not too familiar with the C5 and the meter...why exactly can't u get it to mount..are the holes not lined up properly..?If u can get some pics that'll help alot...i'm gonna try to contact one of the mods to help u..
i only have experience with the wavemaster and the wattage meter so far...
Lov2Drift    0
i'm at work right now but when i get home i'll take pictures of the meter and the case to hopefully illustrate my issues.
its mainly a depth issue from the way i'm looking at it. when you push the locks forward its not grabbing the meter so it won't sit in the bay without screws holding it in.
Mr. Miyagi    2
In some cases it's going to be a little loose. I have a C5, but mine is where the Firewire/USB ports are.
