Tim Conry
MasterCase Maker 5 / EVGA Hybrid SLI
Mektacular    0
I have two hybrid GPU's in my MasterCase 5, but have top mounted both radiators blowing air out.   My CPU (6850K running 4GHz) is air cooled with a 212 EVO, and never gets above 52C when everything is under extreme load (both GPUs and CPU running 100%).  The front of the case is dedicated to air input and I have all drive bays removed.  I'm considering another hybrid GPU and will try to rear mount that radiator blowing out.
Kind of a specific build, but I hope it helps.
