Hybrid-Mods
Thermaltake does it again.. by copying CM
Karma Ghost    0
The CM 120MM fans in the Stacker are nice, they move a good bit of air and are really quiet (sleeve bearing, I think).
If I recall correctly all CM fans use Rifle Bearings. Could be wrong though.. :o
Guest Kingfisher
Guest Kingfisher
The problem with CM products is that for case particularly, it can be 2 times more expensive than TT cases (in EU), which is not worth it. For example, a TT aluminium case worth 89 UK pounds but a CM aluminium case worth 180 UK pounds.
But it does not happen in Asia, so I think CM needs to do something about it then.
Karma Ghost    0
Over here in the states the CM Wavemaster is about 30USD more than Tt Tsunami.
I would still much rather pay for the CM case because if you look inside the Tt it is not nearly as impressive as the Wavemaster's internal.
