Marvin Kaye
SF-17 power supply
Marvin Kaye    0
I purchased an SF-17 laptop cooler and so far am pleased with its performance.  However, the unit is able to be powered by a wall wart supply instead of the USB power and I'd like to take advantage of that option.  Unfortunately none came with the unit, there is no spec I can find for that port and apparently no dedicated power supply available directly from CM... so what's the story??  What do I order from where to take advantage of the power input on my SF-17?  Also, I assume this powers the USB ports as well as the onboard fan, correct???  Looking forward to getting some help here.  Thanks....
  <marv>
