Phil Chen
Mastercase Maker 5 & NZXT Kraken X61 Configurations
Phil Chen    1
Hi all,
I currently have my Kraken X61 top mounted in the pull configuration (Fan on top of radiator pulling air out through the top).
But I'd like to be able to mount the X61 in a push configuration (Fan pushing air through the radiator). I know it does not allow this on the top of the case (there isn't any room to mount the fans below the radiator to push air out the top; interferes with the M/B).
So I tried and mounted in the front of the case (by removing 2 out of 3 HDD bays). I was able to achieve a push through config. up the front (Fans out the front, pushing air through the radiator and into the case), but was unable to install the dust filter in the front...
I am wondering if any of you guys have tried this and was able to fit the dust filter too? Am I doing something wrong?
Tks.
  • Upvote 1
