SeanK
V8 GTS noise and fan problems?
SeanK    0
Hi all, first post here.
This is  actually my first cooler master purchase, and sadly its not going as well as I had hoped.
I purchased the V8 GTS CPU cooler and noticed a really annoying noise coming from it.
The noise alternates between high-low frequency noises constantly. I am at my computer for 10+ hours a day and this noise is driving me insane.
I first thought it was the unit so I had it replaced but its returned. I also noticed the fan constantly revs up and down every 3 seconds.
Here is a link to a video of the noise its making. I am hoping someone here can help me get to the bottom of this.
https://www.dropbox.com/s/0zmpupmb6b1z85n/Video%20Aug%2022%2C%205%2008%2019%20PM.mov?dl=0
please someone help me!
Thanks!
Edited by SeanK
Sunday Morning    174
Hey man
welcome to CM forum :)
my suggestion .. try reinstall your V8 GTS :) and see how the result .. if you still facing same issue .. i would suggest you to contact cooler master support services .
  • Upvote 1
SeanK    0
Hey man
Thanks!
Im going to give that a try tomorrow... Could it be a lack of power maybe? im sure my PSU is enough (650).
my specs:
asus z170a
intel i7 6700 3.4ghz
asus gtx 960
corsair cx650m
corsair 32gb ddr4
Sunday Morning    174
Thanks!
my specs:
asus z170a
asus gtx 960
corsair cx650m
corsair 32gb ddr4
Hey man ..
i think no issue with your psu ...  detail at here : http://www.realhardtechx.com/index_archivos/Page362.htm
and good luck man :)
knud    129
I assume the fan of the V8 GTS is connected to your CPU 4pin PWM header?
What fan profile did you set in the bios (or software tool)?
Can you try to set a silent profile? or set it fixed at ~1200RPM for example?
Does it fix the noise?
SeanK    0
Yes I made sure it was correctly installed twice, and this is my second unit as well.
In terms of fan profiles, i havent changed any settings in my bios or using any software. I entered my bios and my fan was running at around 1000-1200 rpm.
I have tried changing modes in the bios but I didnt notice any difference in noise/performance
its driving me crazy! lol
knud    129
If you have the option, I'd suggest to swap it for a Hyper 212 - those are more quiet compared to this cooler.
