Critrying
Cooler Master Pro 5
Critrying    0
Hi everyone, thanks for joining me here today on the community forums!
I am starting an upgrade to my current build. My first step if finding a case that has some customization tools.
I'm looking at the Cooler Master Pro 5!
Reasons you may ask?
1) Modular, remove DVD/CD /HDD drives for a more roomy fit
2) Airflow / amount of space in the case
3) MNPCTech Racer build found on Bill Owen's site. MNPCTECH.com
4) Liquid cooling mount
I'm going for a "Diablo" Theme build. I used to play Diablo 2 and if I could go back to those days oh jolly Christmas i'd be in paradise.
In regards to Bill's racer build, I loved all the custom things he was able to do. 360 RAD in front, the ignition switch / valve on the front i/o shield, and the AMAZING colours of the case!
Is there a specific "grit" that should be noted for sanding down? I have the primer / paint all set up and good to go. But I'm afraid of sanding TOO much.
Suggestions?
THANKS IN ADVANCE!! Best community ever. I love you guys.
Pclinde    197
Hi Critrying,
Thanks for the kind words! :D I would start with a grit around 320 or 180. :) Or myabe something like this
Kind regards,
Pim
