Renzo Aviles
mastercase maker 5 fan controller
Hi,
I recently got the mastercase maker 5 and I am having trouble getting the fan controller, fans, led strip to turn on. I have the molex connector connected. Do I also need to connect the sata 15 pin?
  • Like 1
knud    125
Yes, you need to connect a sata power cable to the fan hub (behind M/B tray) as well - otherwise it will not power on.
  • Like 1
Tim    0
This may be a silly question, but am I correct that the fan/RGB controller hub that lives behind the motherboard has a male 15-pin SATA power port? I bought a 15-pin SATA to 8-pin power cable to power it up only to find that the male end of the power cable will not fit in the 15-pin power port of the fan hub. Also, finding a 15-pin power cable with a female end has been incredibly difficult.
Can you point me to the cable you bought for this purpose?
knud    125
You just need a regular sata cable. (Which comes with almost any, if not all, PSUs on the market)
Create an account
Register a new account
Sign in
Sign In Now
