Orvin savero
CM Elite 130 Graphics Card Maximum Height?
I have Elite 130, i am planning to buy Zotac GTX 1070 AMP!
But Zotac GTX 1070 AMP! dimensions is pretty big.
2 slots with length 300mm x height 148mm.
http://www.coolermaster.com/case/mini-itx-elite-series/elite130/
only show the maximum length, i have been searching from other site for a while and cant find the maximum height.
through someone build, GPU with 120mm height is possible.
but can someone confirm, is it possible Zotac GTX 1070 AMP! in this case?
Thank you!
Edited by Orvin savero
Sunday Morning    177
Hey
Welcome to Cm forum
Maximum Compatibility as below :
VGA card length: 343mm / 13.5 inch
CPU cooler height: 65mm / 2.5 inch
PSU length:
180mm/ 7.1 inch (w/ less cable management)
142mm / 5.6 inch (w/ full cable management)
Any detail you can ask cooler master support service .
Hey
Welcome to Cm forum
PSU length:
i'm asking the GPU Height, becasue there is no infromation about the maximum height, CM only provide maximum length
Sunday Morning    177
Ya true ... but when iam check detail about the Elite 130 with the AMD HD 7990 as below
Radeon HD 7990 is 11 cm in height ... http://www.hardwareluxx.com/index.php/reviews/hardware/vgacards/21986-test-amd-radeon-hd-7990.html?start=1
Better contact cooler master support service ,they will asnwer regarding this :)
You will be save if the zotac card only 11 CM Height .
Hope this can help .
alright man thanks anyway!
just found it!
CM shows it could fit Asus GTX 780 DirectCU II.
which is 287mm length x 147.3mm height.
so Zotac GTX 1070 AMP! should be fine with 300mm x 148mm
