dracos
PROJECT: DRAGONSTEEL----***COMPLETED***
dracos    0
THey will be exposed in a drive bay, I am mounting my Pump in the bottom drive bay, so i will put them there for air across pump, maybe help to cool it, and bring a little more air into system ...
I have blue plexi which I am going to use to stealth my drives and my fan controller, I am also going to use that blue plexi to create a mounting plate for the 40mm fans...
Mr. Miyagi    2
What's their rated DBA? Wouldn't they be too loud for their CFM or are you going to control with the fan controller?
dracos    0
those fans are rated for 6.7 cfm (but it feel like alot more!) they run at 7500 RPM !! and are only 32db..
I pulled them out of a couple old slave servers/workstations
They are Panaflo fbk04f12h
They sound quieter, but I haven't put them into a case yet to see vibrations etc...
and yes I am thinking of putting them on a controller, I want to try and chain them together off one controller...
SuAsDu    0
Panaflos' are typically pretty quiet, from what I heard, but I'm not really an Air Cooling guy :P
You got some nice progress going. Your etching is just sweet :)
SAD
dracos    0
Update time again!
Time for a peek in the madness..........
BIG PIC HERE
BIG PIC HERE
BIG PIC HERE
I used Hex head screws to replace all the rivets, it is rock solid now...
Here are the drive covers, fan bracket, and fan controller cover.
BIG PIC HERE
And here is the finished fans ready to be installed!!
BIG PIC HERE
And here is some work on the door I did, I decided to attach the door permantly, by doing so it gave me almost another inch of room to move the drives forward...
Need to make cutouts for Power and Reset switch and the usb/audio ports yet, then bondo,sand and paint white!
BIG PIC HERE
firefly858    0
wow...dracos, great progress...thought I might have seen this case some where before :wink: I think the etching looks great. I know if must of taken a lot of time. The gold mirror adds an interesting effect. :D
LPGA    0
nice one dwd, i never like that case but u make that case funny... keep working dwd! ;)
dracos    0
It's been a while for an update, I have been extremely busy with life/work
and new baby...
But here we go..
First I needed to make my wires a bit neater and make them more easy to
control, so I spliced the front 4 together into one connection
And did the same for the back two exhaust fans.
I drilled holes for ventilation in the front bezel, but they looked pretty
bad just as plain holes so I got some heavy metal mesh and painted it the
anodized blue (loos black now) and bent,cut formed them around the bezel,
and attached with Weldbond
Next I got the holes cut for the Power and Reset buttons, also got the leds
installed, also got holes cut and usb/audio installed
Next I had to make the cover plates for the buttons and ports, made them out
of blue plexi, cut and shaped and bent to the curve of the surfe, attached
with Weldbond glue.. Also got the buttons installed and clear plastic button
cover over the leds..
8).jpg' alt='default_icon_cool.gif' alt='8)'>.jpg'>
Now, orignally I was going to make the drive covers blue plexi, but I came
across these cool drive bay covers, so i decided to paint and use these
instead..
Now I need to make the front piece of the bezel, I have 1/4 inch thick red
plexi for that
Here are the progressive shots, using dremel,drill/hole saw and torch to
clean it up, the final shot is semi installed.. going to do some etching on
that as well..
I can't get the damn code to work to link to big pics.. it doesn't like
spaces in pic names.. and I 'm not going to rename all of them.. if you
would care to see the big pics, you can visit my site, it is under Project
Dragonsteel Page 2
That's it for now.. more later this week..
ID    0
Can you give us a link to your site dracos?
I apologise if I I'm missing it, there's so much good stuff to look at!
Oh and congrats on the new addition to the family! :D
Create an account
Register a new account
Sign in
Sign In Now
