Francky
Anyway to fix the Caps and Scroll lock key on the Masterkeys Pro?
Francky    0
Hey guys,
Just recently got the Masterkeys Pro S and I'm very happy with it, pretty much exactly everything I wanted in a keyboard and it replaced my Corsair K70.  (Just wished the version with Blue switches had been available and not 2 months back-ordered here in Canada)
The only Big flaw I can see it the lack of lighting on the Scroll and Caps Lock key when turned off.  Which as we all know is ALWAYS.
Corsair had a very simple and elegant solution for this.  The K70 featured a couple of extra buttons, a mute and windows lock button, yet even when off these remained lit to the color set by the user and simply turned to white when turned on.  If I remember correctly, if the keyboard was set to white, I think then, they simply when to black when turned on.
Any chance this could be done corrected thru a firmware updated?  Or perhaps simpler yet,  anyone know of a way of cheating this in Windows and have them work in reverse, so that they remain lit when actually off?  This could perhaps be the simplest solution.  :)
Thanks guys,
Francky
I also agree the caps lock  gets me into all sorts of trouble trying to access my cryptdata  on POP  OS," is it on or is it off." I have had to get another keyboard just to access my computer
