Emon Khan
Question about Mastercase Maker 5 Fan Hub
Emon Khan    1
I noticed there is a SW1 and SW2 connector what does it mean? The reason I am asking is because I am considering replacing the fan built in fan hub with a pwm fan hub from Thermaltake, but I am not sure where the SW1 and SW2 connectors would go at that point.
Just an educated guess here, but I would imagine the SW1 and SW2 connectors are for the case front panel switches to change the fan speed and cycle the LED patterns. Unless the Thermaltake hub has similar switch inputs you would likely loose the use of those buttons if you swapped the hub.
Create an account
Register a new account
Sign in
Sign In Now
