Andrea Babini
Screech sound in a CM Storm Devastator Mouse
Hallo, I've got a a Devastator gaming gear combo from less than 2 months and a problem, from 3 days, with the mouse: the roll screech and it's very noisy. It didn't fall down, or submerged by dust or liquids. It's a warranty known problem or I should disassemble the device and put a drop of oil/lubricant? In that case could I have instruction to not compromise the functionalities of the mouse?
THANK YOU,
Andrea.
Pclinde    197
Hi,
Disassembly will void the warranty. A drop of oil/lubricant could be the answer.
Cheers,
Pim
Pclinde    197
I had the same issue with my mouse also.
Fixed the issue with a lubricant, works great now.
^ easy as this! :)
