TheSkilletKing
CM Storm SF-19 Gaming Laptop Cooling Pad with Two 140mm Turbine Fans (SGA-4000-KKNF1) not working as well as it used too.
I got a CM Storm SF-19 Gaming Laptop Cooling Pad with Two 140mm Turbine Fans (SGA-4000-KKNF1) two years ago, and it has worked great for me. But recently i have noticed than fans just don't go as fast as they use to, because of this my laptop is getting a little warmer when it used to be nice and cool. So i was wondering if it is something i can fix. Do i need to buy new fans for it? I have used to for at least 1000 hours and possibly am reaching up to 2000 hours, if not already there.
knud    126
After 2 years, it is possible you got some dust inside the fans - have you tried to clean them?
knud    126
Sounds like the bearings are worn out a bit. Might be time to replace them.
Please answer this Question. How is anyone able to change the bearings?
If not, where is it still possible to buy a SF-19 (in Germany)?
Greetings
Create an account
Register a new account
Sign in
Sign In Now
