Daniel W
MasterLiquid Pro 240 Serial Number Help
Daniel W    0
Hello, not sure if I should ask this here but I did not want to open a support ticket for this.  Anyways, I recently purchased a MasterLiquid Pro 240 from NewEgg and I tried locating the serial number.  On the FAQ, it says the liquid coolers have the serial number "Located on the wire of the pump/CPU block" but I cannot find it.  Is there a different location for this particular cooler?  Any help would be appreciated!  Thank you!
Sunday Morning    177
Hey Man
Welcome to CM forum,
If iam not mistake the S/N at on the radiator block
any detail you can contact cooler master support services :)
Hope this can help
Daniel W    0
Thank you Mohd Noh for the response.  I tried looking on the underside of the radiator but the only sticker it contains reads "Warranty void if removed" so I guess I will have to contact Corsair.
Thank you again for the help!
CM Patrick    34
Hello Daniel,
The serial number is on the box next to the UPC code.
It will start with MLYD24MA20MBR1
Patrick
CMUSA Support
  • Upvote 1
Mohd Noh    29
52 minutes ago, Miguel A Lopez II said:
Is the whole number the SS/N or just part of it?
Nah man of course , you need key in whole the number , box and on the frame is the most place to stick in the S/N
if the number is wrong or not correct you can contact customer services ( as in my signature ) , they will help you .
