Derek Hawkins
MasterLiquid Pro 240 pump RPM
CM Patrick    34
Hello Derek,
Yes, the pumps RPM range is 1100 RPM ~ 3300 RPM.
Please let us know if you have any other questions
Patrick
CMUSA Suport
Sunday Morning    177
17 hours ago, Archi Sarroza said:
Hi, Is this the same pump speed to be expected to the non pro version? (MasterLiquid 240)
Welcome to CM forum .
Hi Archi , May i know RPM for your ML 240 ? :)
Owner this Cooling My RPM 1500-3000 run full speed
Please check this link : The Pump RPM of MasterLiquid
If you still concerned please issue ticker to customer services
rahul rushi    0
Hi i purchased cooler master masterliquid 240 and i am using msi mag z390 motherboard even i connected all the connections for pump and fans the pump rpm remains zero can you please help me and my cpu is running at 100 degrees
in even system startup also the temp is incresing from 80 - 100 degrees
i changed thermal paste also and rebuild the pc again even the problem is same
i updated all sofwares and drivers
