Richard
Scout 2 Advanced Water Cooling
Richard    0
I recently bought the scout 2 advanced case and I want to use water cooling for the CPU and the product page only shows rear mount single fan water coolers but I want to know if I can use a double fan cooler on the top? is this possible?
CM Patrick    34
Hello Richard,
Unfortunately, the Scout II cannot support 240mm liquid coolers. It can only support a 120mm radiator at the rear of the case.
Please let us know if you have any other questions.
Patrick
CMUSA Support
Sunday Morning    177
Hello Richard,
Patrick
CMUSA Support
:P
Sunday Morning    177
Hey Man,
Here is some picture for your reference : http://community.coolermaster.com/index.php/gallery/image/2282-seidon-120v-with-dual-fans-jetflo-120mm/
Edited by Mohd Noh
Luke    0
Hi CM.
Could you please advice if the new generations of 120 liquid cooler could be used for scout. Or is the liquid cooler limited to Seidon 120V only.
Mohd Noh    29
5 hours ago, Luke said:
So the new products like master liquid pro 120 should be compatible?
Please contact customer services for more detail but i believe they not compatible with scout 2 because of the fans maybe touching the tube
Below is scout 2 white with seidon 120v
jwts    0
Instead of create new thread for same topic, i will write my question here :wink:
I have CM Storm Scout 2 Advanced. Now I want to buy an AIO Liduid Cooler and Enermax Aquafusion 120 is available now in my country. Is this cooler could be fit in my case (rear case). Dimension is 154mm x 120mm x 27mm.
FYI, I bought Corsair H60 (2018 version) and it didn't fit in because I think the radiator height is 157mm.
Below Enermax Aquafusion dimension (i got it from product web site) :
