fatgump28
Coolling for HAF 932
fatgump28    0
I purchased a  Corsair H110iGT to go with my Cooler Master HAF 932 , I7 6700 and the mounting holes for the radiator do not line up. Do you have any suggestions for one that would fit and come with the correct adapter for LGA 1151?
Sunday Morning    177
Hey
Welcome to CM forum
Here is some for you reference : https://pcpartpicker.com/b/N7tJ7P dont know if this link can help you
The new 1151 socket has the same mounting as the previous 1150/1155/156 sockets. All coolers that supported the previous sockets will support the 1151.
Any question i would to suggest you to Contact Cooler Master Support Services
Edited by Mohd Noh
CM Patrick    34
Hello fatgump28,
The H110i GT is a 280mm radiator.
The HAF 932 will only suport 240mm and 360mm radiators at the top.
Patrick
CMUSA Support
