Connecting fans/leds to Storm Trooper/Stryker front panel controller.
Xion    0
Hi. I am currently working on building a PC for the first time. I am interested in using the Storm Trooper/Stryker chassis for my build. Based on the case manual, the front panel fan controller have 4 connections for fan power (3 pin) and 3 connections for led (2 pin). Has anyone with this case attempt to connect more (speed & led) to the front panel controller using splitters? What is the maximum that people have done? Are there specific quality splitters, if any, that I would use?
It seems if I want to be able to turn led on/off, I have to use Cooler Master BC fans which has the separate 2 pin led cable. How about the fan power 3-pin connectors? Are they specific to Cooler Master Fans or can I use Noctua or Corsair fans with the 3 pin connectors?
Edited by Xion
CM Bram    35
You can connect/split from the controller to more fans and/or LEDs, altho I am not sure of the max number..
Create an account
Register a new account
Sign in
Sign In Now
