H4CK3D
CM Master Flow 5 ?
H4CK3D    0
Hello dear CM Community,
for the beginning i'm sorry for my bad english :P Learned it from playing games (not school).
I'm a person that doesn't like to watercool GPU cards, why?
Because i change a graphiccard each 2 years or each new architecture for example 40nm > 28nm (14nm Pascal).
So selling a GPU with a waterblock is way harder than selling it without one.
I do this Mod to make my system run quiet and cooler than in any other case.
I have many ideas but no company cares about this...
So i will mod my own case to see how my mod can improve the airflow.
Maybe CM will build a case called Master Flow :) (That's also my goal).
Stay tuned!
PC:
CPU: 4790K + Intel 120mm Watercooling.
GPU: Zotac 980ti AMP Extreme
MB: AsRock Extreme 4 Z97
RAM: 4x4 TridentX DDR3 2400mhz CL10
SSD: 2x SSD
HDD: 1x HDD
PSU: BeQuiet Dark Power P10 650Watt
Currently thoughts:
TOP: 2x 140mm
Front: 1x 140mm, 1x 120mm
Side: 1x 140mm, 4x 80-92mm
Side(tray): none
Back: 1x 120mm
Edited by H4CK3D
